Yogesh
Take this test to see if you can discern between audio qualities. You may be in for a surprise!
Right. The equipment matters a lot to identify the differences. However, I used headphone (Sennheiser HD 4.40) with my PC, so it was comparatively easier to notice the details. But even then it was pretty close between 320 kbps and WAV. I'm not sure whether I would have noticed it if I had played it in my speakers.Do share what you used for playback
As I understand the differences are more apparent with more resolving and higher quality setups
I totally subscribe to this view.....Do share what you used for playback
This is a hugely debatable question isnt it ? Just like in any field - only passionate would probably find the difference or the worthiness in SQ or the related gear. My kids are happy with their mp3 players / Smart iPhones etc - and they often ask me - why do you spend this much money on these units ? The icing on the cake is when you dear wife says - so - "whats the difference now?? LOLA fundamental question I want to ask. Does it require the ability to differentiate SQ in a A/B test in order to benefit from higher SQ while listening to your favourite music, in a non-testing environment? I am not so sure. Good sounding music will have its effect on the listener, even without them realising it.
That’s not quite what I meant. I am saying SQ can improve the quality of listening experience even if one isn’t consciously aware of the exact difference. Somewhat like filtered water keeps your body safer even if you can’t make it out from tap water in a A/B test.This is a hugely debatable question isnt it ? Just like in any field - only passionate would probably find the difference or the worthiness in SQ or the related gear. My kids are happy with their mp3 players / Smart iPhones etc - and they often ask me - why do you spend this much money on these units ? The icing on the cake is when you dear wife says - so - "whats the difference now?? LOL
my bad .... but yes - totally agree. Better SQ does makes it more enjoyable - subconsciouslyThat’s not quite what I meant. I am saying SQ can improve the quality of listening experience even if one isn’t consciously aware of the exact difference. Somewhat like filtered water keeps your body safer even if you can’t make it out from tap water in a A/B test.
With resolving gear and keen listening, yes. The probability increases further if you are listening to a favourite track over its entire length.but wouldn’t you agree - some people especially audiophiles can easily pick out a well recorded track with good SQ ?
