HT and projector setup suggestions for Bedroom
Lucifer9324
mumbai
Hi everybody, This is my first post on this forum. I found it on reddit while looking for advice for my new home.
I want to install a home theatre and a projector in my bedroom and want to make it into a room for media consumption. I contacted a local HT dealer and he gave me a quote of a ONKYO 5.1 HT system for 75k and the PRIMA NOVA S4K for my projector. I want to take a DIY approach for the same. I wanted some advice for the same. My budget for the entire room is around 1l. I need to fit a decent projector, screen and a HT system in the same. I am considering the Denon x580bt AVR and some in wall speakers from Micca. I would like to upgrade as per my need in the future. I am considering the veiwsonic LX60HD for my projector. My room size is 11'x17'
Any recommendations or any product suggestions would be a big help.
For the budget, it should be fine. However, if you can go with two speakers first and rest later, you can fit some floorstanders or nice bookshelves in that budget.
