The motherboard on my Popcorn C-200 packed up recently. Have decided to build a HTPC rather than importing an A410 for ~25k. The PCH support sucks and anyways I don't intend getting a new PCH motherboard
Will cannibalize the HDD bay on the C-200 for use in the HTPC
Below is the configuration that I have in mind.
Its a no holds barred overkill build, although I will be using it mainly for bitstreaming FLAC/DTS HD-MA and watching ~ 20gb mkv movies.
Planning to procure the CPU cooler/Case Fans/Memory and SSD from the US thru a cousin.
The cabinet thru eBay Global and the CPU/MoBo and PSU locally
Cabinet
Silverstone Tek Grandia Series Aluminum HTPC for ATX/SSI-CEB Computer Case GD09B
CPU
Intel Core i5-4590 Haswell Quad-Core 3.3GHz LGA 1150 84W
MoBo
Gigabyte GA-H97-D3H H97 Motherboard
MSI H97M-G43 LGA 1150 Motherboard
(The Cabinet can accomodate an ATX board and am keen on the Gigibyte. However it doesn't have a SPDIF Toslink/Coaxial output port on the rear. It does have a S/PDIF out header on the board. However not able to find a decent S/PDIF out plate. Hence might settle for the MSI Micro ATX which has all the output ports as the Gigabyte plus the S/PDIF Optical)
CPU Fan
Noctua Low-Profile Quiet CPU Cooler for Intel 115x Based Retail Cooling NH-L9I
Memory
Crucial Ballistix Sport 8GB Kit (4GBx2) DDR3 1600 MT/s (PC3-12800) CL9 @1.5V UDIMM 240-Pin Memory BLS2CP4G3D1609DS1S00
Case Fans
Noctua (NF-P12 PWM) - 120mm Two Speed Premium Fan, 1300/900 RPM, SSO2 Bearing with NE-FD1 PWM- 3pk
Power Supply
Corsair CS Series Modular CS450M 450W 80+ Gold
SSD
Crucial MX100 256GB SATA 2.5" 7mm (with 9.5mm adapter) Internal Solid State Drive CT256MX100SSD1
The choice of components is inspired from the techbuyersguru.com page HTPC build.
Total cost will add upto ~55k
Planning to use Open ELEC and XBMC (Kodi) as the interface
Am open to ideas/suggestions from the HTPC Gurus on our forum to improvise on this proposed build
Cheers!
Cabinet
CPU
MoBo
CPU Fan
Memory
Case Fans
Power Supply
SSD
Cheers!
