HTR-3067 + NSP-40 + SW030 - need advice
mehimansu
Hello,
I would like to get an advice on following combination of home entertainment from yamaha:
A/V Receiver: HTR-3067 + Satellite Speaker: NSP-40 + Subwoofer: SW030
Here are my queries:
1. Would the above combination be anything better(sound wise) than what i would get in Yamaha YHT-2910 package?
2. What other alternative I could avail instead of above combination in same budget?
@mehimansu, since you are in Bangalore, why don't you try and get a demo of both and decide for yourself?
At this price range, spending more money on speakers gives a better bang for buck than spending similar amount on AVR. So, I suggest getting a Pioneer VSX 323 (around Rs.17K) and getting a better set of speakers. Get a Pioneer AJ or Polk TSx series 5.0 (no sub) or 3.0 (no sub or surround, only fronts and centre) speaker set. You will have a much better end result.
