IEM Cable
spacenoxx
India
I have a pair of Sunrise Xcape IE buds. I really like them compared to the PL-30 I have. However, a couple of days ago one of the speakers stopped working and I realized that the cable might have gotten damaged internally, near the jack, cause if I align the cable and the jack in a certain way, both the speakers work.
The Sunrise IEMs are designed such a way that I can use a different Stereo cable and solder them and they should (hopefully :-) work all right.
Could someone suggest me where I can get a decent quality headphone cable?
I am from Mumbai.
TIA
Unless you have a removable cable IEM like TF10's , IE8 i dont really think you get specific headphone cables , why dont you cut the part causing the issue and resolder the remaining if you are good at soldering .
