If the Yamaha AVR is not powerful enough to drive Taga 5.1 speaker set....
Naveenbnc
Hyderabad
Hello all,
I ordered Taga Harmony TAV 606 SE. I have an AVR from yamaha YHT196 (100w, 6-ohms, with only "ONE" channel driven.
If this Avr struggles to power the taga speaker set, is there any thing we can do other than replacing the avr? (I mean is there any cheap solution?)
Naveen
Hello all,
Naveen
The towers have 91 db sensitivity, unless you need very high volumes or have a very large room then you should be fine.
