I'm Back.
Srinath_seshadri
Charlotte NC, USA
What, you guys never realised I was gone ... grrrr ...
Anyway, I gave up my work laptop, and then sorta had to re remember the ID and password etc etc ...
The gear update (some people probably going to be sad ... but I am not) I sold 1 set of B&W 802's after buying a broken set of 802. Then repaired the broken 802, and ran it a while. Its needing a couple hand made parts still ...
Sold the altec cabinets (the 421+811+511 is still around waiting for its cabinet.
Sold a bunch more ... got a bunch of stuff out of storage.
Bought a bunch more Dead and live amps, speakers etc etc.
Rigged the PCS8+FCM8 combo to work as a single speaker not needing bi amp.
Then I stuck a finger in the foam edge to "test" it, and well it didn't fail the test ... I did. I had to take it out a refoam it, which I am doing in rubber.
Fixed my infinity ref 4's, fixed the bose 901 series 1, re-capped its EQ, peeled the clear coat off the sides of the EV's.
Anyway I'll be on here more regularly (I hope).
Cool.
Srinath.
