in market for 22 inch lcd tv
tortoise
Back in the forum after a long time. I am planning to buy a 22" lcd/led. Following are the requirements
1. Will use it as monitor (should be good for text display - if there is a predefined setting for monitor use it will be good )
2. should have USB and support most movie formats through USB
3. good picture quality ( minimum ghosting )
4. around 15k max price
Which among the LG, Sony or Samsung models should I pick up?
Check on letsbuy.com, there is a toshiba 24 incher for 16k . You can use some coupon codes to get 500-1000Rs discount.
