Increase Headphone Volume
jaypee307
India
I have Samsung Series 4 32 LCD TV. I prefer to watch TV mostly with headphone. My TV my does not have a dedicated Headphone jack. Instead, there is an audio out (3.5 mm stereo) to which I have connected the headphone (while keeping the TV speaker Vol to minimum). Some programmes/DVDs volume is a bit lowbut if I increase the TV volume, the TV SPEAKER vol increases, not the headphone's.
How can I increase the headphone volume? Using an Amplifier? if yes, which type is preferable?
Thanking you,
Jose
1) See if in your settings audio output can be set as Variable - Instead of fixed....that will sort out changing volue level
2) There are small headphone amps available which are portable and having chargable battery
check hifimart
Headphone Amp
this is good priced
FIIO E6 Portable Headphone Amplifier
see if someone in your area having it..what is ur location??
BTW long back I found that wireless headphones have a small amp and sometimes that is sufficient.. and there are cheap wireless HP available ( by intex and other it brands) for Rs 800-900 - see in case of you it helps...
PLEASE POST YOUR "EXPERIMENTS AND OUTCOMES" FOR BENEFIT OF ALL.
Hi, thanks for the reply.
I am from Thiruvalla, Kerala.
Does Infrared Wireless Headphones also have an amplifying transmitter as RF ones? IR seems to be the cheaper ones.
Jose.
