rwnano
I have a Harman Kardon AVR 240, 50 watts per channel 7.1 system. Its got high current capability.
This is how the Rear-side of the Amp looks:
https://i.ebayimg.com/images/g/lUUAAOSw29FjE3Eq/s-l1600.jpg
Qn1. Apart from the SubWoofer, how do I use the Pre-outputs of the Amplifier. ???
I currently have 5.1 HKTS 11 speakers with Front Left and Right as Jamo S60 SURs for a total of 7.1 speakers in my bedroom all arranged on one wall-face.
Music is plenty loud and clear for this room both in Stereo mode as well as 7.1 mode.
** Laptop is playing FLAC files to Topping D10s DAC which outputs to the analog IN of the Harman AVR 240.
Qn2. How else to improve sound quality?
N.B: my DAC reads 44.1 PCM when it plays - so I do know that I need to use ALSA out to improve the sound quality.
Note: My subwoofer is a passing Harman Kardon HKTS 11 200 Watt sub, with its plate Amp removed, and is powered by an external SubWoofer amplifier.
Thank you!!
http://en.all-specs.net/model/135040/
10
100
75
Thank you!!
Inputs
composite x5, S-Video, x5, component x2, coaxial x3, optical x3, 7.1CH x1, linear x7 input for iPodhttp://en.all-specs.net/model/135040/
Outputs
subwoofer x1, composite x3, S-Video x3, component x1, headphone x1 coaxial x1, optical x1, 7.1CH x1, x3 linear, PreAmphttp://en.all-specs.net/model/135040/
The connectors on the front panel
headphones, line input, composite input, S-Video input, optical input, coaxial inputhttp://en.all-specs.net/model/135040/
Digital sound processing
DSP
there, Cirrus CS 4940010
The sampling frequency of the audio DAC
192 kHz100
Bit audio DAC
24-bit75
