Raaj DSV
Dear All,
Hope you are all fine and staying safe.
Soon, I want to install a new Integrated Amplifier & a pair of Bookshelf Speakers (Either normal ones or powered ones) at my desktop space where I usually sit and listen to the music for very longer hours. Soon, I might also build new desktop too with AMD Ryzon 4000 APU series CPU too. The source of music would be FLACS primarily through Desktop computer and Audio CDs from a CD player and sometimes movies from PC.
My total budget for AMP & Speakers would be around 70,000/- (Can be slightly extended if needed)
Integrated Amplifiers Options that I was thinking as of now: (Not sure if they are still good enough as they are already four or five year old models already...Or are there any better options? )
1. Marantz PM6006 Integrated Amplifier
2. Denon PMA-600NE Integrated Amplifier
And not sure about the speakers... How about Wharfedale Diamond 11.1 or 11.2 series or Polk S15 or S20? Would they be perfect match for these Amps or they fail to deliver enough power to these speakers? Would they serve enough bass or I need sub woofer?
Thanks in advance for your recommendations/suggestions.
Raaj.
Raaj.
