keith_correa
Guys, for the past week or so, I've been anally tweaking my low end Windows 10 laptop to extract the maximum performance from it for audio playback. I've browsed a lot, collected tweaks from all over, read MSDN a lot [much more than I used to do when I used to code ], implemented the "tweaks" and have made rough [very!] notes on what I did. I have got VERY good results to the point that running the free version of "Fidelizer" in Extremist mode does not add anything positive to my system. In my current state of madness, I feel that if I put together a document or pdf with what I did to attain this level of performance, others could benefit and also save money in buying software that will tweak Windows to audiophile levels.
Things that I would want to make clear in advance:
Now after you reading through the negatives listed above, before I start putting this together, I want to invite opinion from the community on the best way for me to do this OR whether there is interest in this at all from the community.
Please let me know what you folks think and thanks for reading through.
- These tweaks are collected from various sources over the internet. 99% are not my own. I will not be able to provide the source from where I got these simply because I have not kept track.
- These work superbly on Win 10 Professional running on my 8 year old laptop with a 64 AMD Turion 64 processor and 1.5 GB of RAM that I recently saved from being thrown away. I'm using a USB DAC and JRiver as the media player. If they work well on this laptop, there is no reason why it will not work on your modern machines. hyeah:
- I will not be able to provide screenshots for implementing most of the tweaks because that is just too much of work for me. So this means that some amount of "expertise" is expected from folks wanting to implement this.
- If you junk your OS by implementing some/all of these tweaks, you are on your own. I will not be able to help you restore the OS back to it's original state thought a simple OS reset should restore things back. Having said that, I have not thrashed the OS yet when I implemented the tweaks!!!
- I will not be providing any JRiver tweaks because that is too specific and folks may be using their own media players so I think it's best to keep the tweaks confined to the OS.
- My laptop is being used for NOTHING else except as a music player so some tweaks disable a lot of functionality. Where ever possible, I will try to put in Notes saying what will NOT work if a tweak is implemented - but don't expect that I will put this in all the time.
- I will expect you to take snapshots before you implement a tweak so you can revert back to the state it was before implementing a tweak if needed.
- I will do this in my own sweet time so do not expect a quick turnaround on anything because my other life will take priority over this.
- This will be a WIP as more tweaks are discovered and implemented by me and I would expect others to contribute too and I would update that central "repository" to include those tweaks.
- Microsoft's updates to the OS probably will PROBABLY back out some implemented tweaks which means that the tweaks MAY have to be redone after any update to OS components etc.
- I do not know if these tweaks will work for Win 7 or 8 but most should. Windows Server 12? I don't have a clue.
