Let me share my personal experience here.
I presently own 4 NP deisgned amps from various periods.
One Adcom Class AB, another Adcom Class A Bias designed for car (which i mostly used at home), the AmpCamp (a very simple Single Ended Class A) which I am using now and another DIY under making which is broadly based on his Aleph design.
The AmpCamp which I use now is a simple 5 watt Class A amp powered by a laptop adapter.
It is a poorly measuring amp and very poorly rated in some forums like Audiosciencereview subsequent to its getting very popular in the diyaudio community.
It is ofcourse of very minimalistic design and uses feedback and 2nd harmonics primarily.
When paired with the right preamp and speakers, it sounds exceptional.
Many use a term musical which in my opinion is subjective.
It does not colour the sound in my opinion by having no exaggerations and has very clean and open midrange, good and taut lows and and good details in the highs.
Yes, with speakers needing good drive, it can struggle to provide loudness, but even therein, it delivers the full range without loss of details for near field listening.
I am running it presently on my DIY Infinity speakers which are reasonably sensitive at 89db and have also tried them on some very good power hungry speakers like the KEF R3, Revel Concerto and some floor standers at the Bangalore meet.
I have also run it on high sensitive full rangers like the vintage Altec Lansing and it has held its ground.
Overall it does its job very well keeping the measurements out, though some of the basic measurements are still well within the audiophile range.
The measurements which are normally not that audible or need high resolution gear in a properly treated room will most definitely bring out the flaws, but in normal home environment, this is an exceptional sounding amplifier.
In my experience, measurements are very important but too much clean-up can sometimes be too dull or flat sounding to an organic ear.
To add a but of naughtiness, the great Bernard Shaw once commented that
"A woman can indicate with her euphoric voicing if the experience was organic or mechanical, unlike the men".
