Interesting thread on avsforum
crisscross
Hyderabad
Thats some crazy toolset he uses. Seems like its his workplace so having it done by someone personally would be very hard unless they worked in a similar environment.
Makes me want to do an internship at a speaker manufacturer.
I was searching for CNC on JustDial and found quite a few "CNC job work" companies. Might be worth talking to them.
Sumit: So you are going to build it for us ;)
Cutting a perfect circle is not easy without CNC but you can achieve similar results by getting a hole cut roughly to the required dimension then filing and sanding it. The manual work would take hours of work what CNC can do in minutes.
Do you have the CAD drawing for the parts ? If not ,then it also takes time to program the entire thing into a CNC language and it shall be quiet expensive to outsource it to a an engineeing works as they shall charge a lot for this. Its better idea to pool few people who want it together and produce the sub-woofer in larger number , then the costs will come down.
