Interior Decorator in Chennai?
gman
chennai, India
Here is how my living room is:
It only has two opposite walls with a large glass door on one side and lounge + dining hall on the other side. The wires will have to go thru the TV wall .. to the ceiling.. and then to the opposite wall where the sofa is. I can hide the wires to some extent by making it run just above the curtain. Note the wall behind sofa. Here is where I would like to get some work done that would totally conceal the wires for the rear speakers ( I would like to do better than just running pipes and passing the wires through). Something similar to how good demo shops have everything concealed except for the speakers (false ceiling sort of arrangement).
Has anyone got similar work done at their place in Chennai? Any contact numbers?
Would appreciate if someone can respond. Right now my HT usage is very low primarily due to the lack of surround speaker position (I do have the speakers though). It is going to drastically increase if i can crack this hurdle. :)
I got these things done during construction stage itself. My builder's supervisor had been pro-active on such niceties. Now, this guy himself has become a small time builder. You can contact him on 9043344540 & his name is Jeeva. Hope he can sort this one out for you!
Cheers!
BK
Looks like it is flat of TVH Ouranya bay ?:)
No other choice you have to bring the wires from(via) the ceiling exactly opposite for the surrounds. Surrounds shall be kept just above the sofa seating with slight inclination towards ears:cool:
Cheers!
BK
Spoke to Jeeva. He is from Avadi and my place is diagonally opposite in a way and may be 60-70km :) So, that didnt work out. Just an update.
yes,Thanks for the inputs. This was a ready-to-move-in flat so didnt have the chance to make any mods.thanks
w24mVL
