Inverter connected to led 46'
pranay
india
i have connected an 800va inverter to sony led 46' when the power goes off there is a time difference of 2-3 secs causing the tv to switch off and on what is the solution for the problem will my tv get spoiled
The tv can get spoiled if the voltage given by the inverter is above 240v,all flat panel tvs in india are designed to operate at 240V max.
Also if you do not have a stabilizer and if your main line voltage is more then 240v again it can have a toll on the tvs life.
Your inverter should have a PC mode where the switching time should be faster,this should solve the problem of tv switching off,if not you need to get a computer UPS.
Instead of inverter use a UPS. Ordinary 600VA offline ups is enough. If there is voltage fluctuation then line interactive or online ups is recommended.
In my present residence I am using the Sukam 3.5 KVA Pure Sine Wave Commercial UPS, this product is a fantastic one and I am able to run all my house hold goods through it except Airconditioners.
