rajeshpapani
is 4k upscaling really works on TV?r market gimmick?
Upscaling certainly makes a difference but is not a patch on the original 4k content. That said on large screen TVs upscaling makes the standard def content looks presentable.is 4k upscaling really works on TV?r market gimmick?
It depends on the picture processors in TVs. That said, there is also some hype involved. Most TV's claim their upscaling is good. Alpha 9(LG), X1 ultimate(Sony) etc... are actually good and lives up to the hype.is 4k upscaling really works on TV?r market gimmick?
is nvidia shield upscales on low branded TVs?No, it's not, but the final result depends on how it's implemented and differs from vendor to vendor (Sony leads the charge though). 4K upscaling offered by Nvidia Shield Pro is a pleasure to watch.
Well, basically if you play a 1080p content on Shield Pro, it comes really nice on a decent 4K TV post upscaling. If the TV in question, can't display a native 4K content properly, any upscaled content will also look bad, no matter how good it was upscaled.is nvidia shield upscales on low branded TVs?
i hv ifalkon k71 (tcl p715) 4k,hdr 10,10plus support ,evry one on this thread recommend sony x1,nvidia .i think Nvidia supports 4k upscaling only on online streaming ,what about DTH channels ?should i buy sony x1 TVs or any othersWell, basically if you play a 1080p content on Shield Pro, it comes really nice on a decent 4K TV post upscaling. If the TV in question, can't display a native 4K content properly, any upscaled content will also look bad, no matter how good it was upscaled.
If DTH (HD channels, 1080i) is your primary source of content, then any top/mid-tier Tv from Big 3 should do the trick. That said, 430i contents come really bad on a 4K tv no matter which TV you opt for.i hv ifalkon k71 (tcl p715) 4k,hdr 10,10plus support ,evry one on this thread recommend sony x1,nvidia .i think Nvidia supports 4k upscaling only on online streaming ,what about DTH channels ?should i buy sony x1 TVs or any others
@lightgameris 4k upscaling really works on TV?r market gimmick?
Sure, let me go through the thread.
Completely agree. The shield and shield pro 2019 have much better upscaling than any TV out there.Not sure about TVs but in my nvidia shield it works and does add definition
Agree here too. Upscaling won't make 480/576p content look like 4k, or even 720p. But it will add that little bit extra definition to jagged edges to make it look watchable.Upscaling certainly makes a difference but is not a patch on the original 4k content. That said on large screen TVs upscaling makes the standard def content looks presentable.
X1 isn't really that good at upscaling. X1 ultimate is however quite decent and XR(2021) is good.There are X1 from Sony which are wonderful in doing so.
Yes, it just feeds the upscaled signal to the TV. The screen doesn't really matter here.is nvidia shield upscales on low branded TVs?
is madvr works with TVSure, let me go through the thread.
My thoughts:
Upscaling will never look as good as native content unless it's using really advanced algorithms. Even something like MadVR which I use on NGU Sharp can barely make a good high-bitrate 1080p look like 1440p at best. And this is using the full power of an RTX 2070 Super with his proprietary algorithm which is one of the best in the industry.
Also when people say Sony/Samsung/LG has great upscaling, that only refers to their top of the line models. Budget models of any big brand have terrible processing as they cheap out on every rupee they can to cash in on that brand name margin.
The best way to get a sharper image on your TV is to feed it a better signal. If you're streaming, try to watch on devices that don't have DRM restrictions and at least match the content in quality. If you're downloading content, try to get the best-encoded version available to download.
Upscaling is always a last resort when you can't get the content in any better quality, and that is the only way to increase it. It only matters if you watch a lot of DTH or low-bitrate content. And even then, not much. The different between the best TV upscaler and a mediocre one isn't very high. You can get way bigger delta by switching to better sources.
From what I've seen regarding upscaling:
MadVR > Shield 2019 >>>>> Sony flagships > LG/Samsung flagships >>>>> other TVs.
Not sure where Apple TV 4k/firestick 4k stands here. Unfortunately not many have tested their upscaling capabilities. The Apple TV 4k 2021 has a lot of grunt with the A12, so I'm sure they're using it somewhere.
Yes, it works with any display. You need a good PC to power it and a good weekend of setting it up.is madvr works with TV
so pc is require for madvr, i think Nvidia shield is better optionYes, it works with any display. You need a good PC to power it and a good weekend of setting it up.
Depends on your use case. I already have a PC in my bedroom, so I'll just connect a long HDMI cable to my TV when I move the U79 there and get a better living room TV. No extra cost required.so pc is require for madvr, i think Nvidia shield is better option
