Is Q Acoustics Q2000/i speaker stand suitable for Sonodyne BS
RMCWS
Calcutta
Are Q Acoustics Q2000/i speaker stands suitable for Sonodyne BS?
The top plate of the stand is 9x5" (approx)
While sonus 1501 bs is 10x7.5" (approx)
The weight of the speaker is 5.3kg.
The columns of the stands comes with factory filled acoustic foam.
My question is that will this stand go well with a sonodyne bs or say any other bs speakers with similar dimension and weight?
I had similar doubt when i bought stands from FM (Magma - Sound Foundations) for my Wharfedale diamond 9.2's...
When i spoke to him, he said that base plate would be smaller than the base of the speaker, so that it would get hidden when the speaker is placed on top....
I know that. But I am confused as how much smaller base plate can be allowed comparing to the size of the speaker base so that the speakers stays there safely.
