I think I will buy this system (JBL Cinema BD100) for my Bedroom!
However, I've never tested these speakers. In case, anyone has any experience with this system, then do share your thoughts!
I believe you cannot go wrong with JBL/Harmon; moreover this system provides an excellent Blue ray receiver.
So Guys do share your thoughts.
Specs:
Audio Specifications
Total Output Power 300W RMS (20% THD)
Input Sensitivity 250mV/46k ohms
Signal to Noise Ration 80dB
Dynamic Range 80dB
THD+N at 1W output (20Hz~20kHz): 0.5%
Frequency Response 1W (3dB): 20Hz 20kHz
System Specifications
Power Requirement 100 240V AC, 50/60Hz
Power Consumption (Full Power/Idle) 90W
Satellite Speaker Specifications
Satellite Midrange Transducer 2-1/2" (63.5mm)
Subwoofer Specifications
Subwoofer Low-Frequncy Transducer 5-1/4" (133mm)
Speaker Midrange Transducer 2-1/2" (63.5mm)
FM Tuner
Frequency Range 87.5MHz 108.0MHz (US and EU)
Signal-to-noise ratio (mono/stereo) 55dB/55dB
Distortion (mono/stereo) 0.3%/0.5%
Stereo separation 45dB @ 1kHz
Image Rejection 70dB
IF Rejection 80dB
