Jico Stylus
Hi all,
I had used a Jico Stylus for my AT-91 cart a couple of years back and would say that it sounded as good as the original.
N.Murali
I intend to buy the normal Jico on Shure V15 Type III for my LP12. At $78 for the stylus plus Rs1000 for the body, can't call it expensive at all. If it works out well, I will probably go for VxMR.
Based on all the reviews I have read for the V15+Jico SAS combo, I'd just go with the SAS straight...
SAS I will keep for when I go for VxMR. For Type III normal is enough, I think, just in case the body I got is not quite all that mint...
