L/R inputs in sub?
arjunbabu
Thiruvananthapuram
I'm a noob and have very limited av knowledge and this might sound silly. I'm planning to buy Polk PSW 125 sub to be paired with Denon AVR 2400h. Like most avrs, This AVR too has a single channel rca port where you'd only have to plug in just an rca cable. However, this Polk sub has 2 ports for input. L and R. How do I connect this sub to the Denon AVR 2400h?
Thanks and Regards,
Arjun
Thanks and Regards,
Arjun
You can use either of the inputs on the sub to connect with an rca subwoofer cable
On the back of your Sub, one of the line in (L/R) inputs will be marked as LFE to which you can connect the RCA cable that gets connected to the SUB out of the AVR.
