I dont think the use of laminate will impact the sound quality.
Further a good quality laminate will be easy to use, partly scratch proof, more durable and cheaper as compared to wood veneer.
Real wood will be more durable, just get is polished once in every in 5 years, however is prone to attack from termites. At the same time it will be difficult to get the wood for making the speakers and will be a costly affair. Not sure how it will impact the sound quality.
Wood veneer integrates with the rest of the cabinet better, which is usually built out of MDF. Laminate, if not pasted absolutely correctly will induce vibrations messing with the imaging.
Make cabinet with MDF not wood ....finish can be wood veneer which will look rich..use matte lacquer over wood veneer after polishing to give it a long lasting .........laminates are always cheap alternatives but easy to maintain.....
Wood veneer will make you tear your hair out in frustration if you do not have know how to bond it minus nails. Difficult to work with but the sonics & appearance are worth it.
Yes you can use nails but then the appearance will be inconsistent around the area with the head less nails & uneven as well.
Wood veener comes in 4mm thickness. So matching corners is always a challenge. If you go ahead with wood veeners, get in touch with some experienced carpenter first.
A polished veener always looks far better than any laminate (IMO only).
In case you are concerned about pasting, use Araldite instead of Favicol. This might cost some extra money.
Veneer is very thin. Like a thickish sheet of paper. It is made by shaving it off a rotating log with a very sharp blade. That's what results in the repeating grain patterns.
But I agree with your "IMO" --- veneer is real wood, laminate might be, but doesn't have anything like the same look and feel.
Applying and finishing it, though, is a real skill. I had a friend who took it up as a hobby, and over several years I saw his pieces (including complex marquetry) progress from looking very rough to looking professional.
hey guys i am not talking anything about doing the lamination or finishing myself.
a speaker i am looking to buy, the company (omega speakers) has an option of laminate finish or wood veneer finish. the latter is $200 more. so i was wondering ...
I'd say its a matter of appearance, rather than anything else.
How much does that matter for you? How much do think that speakers should be good-looking furniture as well as producers of sound? How long are you likely to keep them? Can you easily afford the veneer, or are the speakers themselves stretching the budget as it is? Does the laminate one look great anyway?
Thad
First part is correct. Second part- high value timber logs are veneered using veneer slices ,and the technique is not like peeling, but slicing:
Laminate, done well looks cool and almost seamless at the edges. It will not affect the sound at all and for a difference of $200, I'd go with laminate. But then, I'm cheap
