LED for dad..32 inch or less
yabbadabba
New Delhi
hey guys..please advice.
Requirements-
1.32 inch or less
2.budget max 25k
3.no preference to any brand
4.warranty,the more the better
5.PQ,as much as I can in this budget.
Requirements-
1.32 inch or less
2.budget max 25k
Buy toshiba or sharp in this budget... They will be vfm... Rest known mnc brands will be outside this budget...
I use a Toshiba PU series 32 inch....purchased for 21k (Mumbai) with 3 years warranty....works too well with USB port (28 movie formats) and multiple connectivity options.....
Sharp just announced a couple of weeks back about extended warranty for their products..definitely the PQ is better than Toshiba.....do some window shopping at a Vijay Sales / Croma / E Zone / Reliance Digital....shortlist a few brands / models...decide and then check with your local dealer the best price...also compare the prices available on flipkart or snapdeal.....
I did responded to some TV related posts...click on my user name to read them...hope this helps
If you're thinking of Toshiba don't get the PU series coz its old now.. P2305 has better features + Latest model and most of the showrooms now a days have it so you won't find it hard to get a P2305..
demoed toshiba and sharp leds today..the guy said newer models would be arriving within a month..so i think i should wait a while for them.
You are right, but cost wise they will be more compated to 2013 models... So u may want to take call based on this tradeoff...
@yabbadabba : Sharp and Toshiba is good with 3yrs warranty and within 25k range. Myself using Sharp as second led for almost a year now which was for Rs 21,000 .New models are coming but will be high on cost for sure.Just check whether extended warranty is on Panel hardware or only on repair cost. Some Toshiba led have non comprehensive warranty.One more thing the sound(Speakers ) of Sharp and Toshiba Led is of inferior quality maybe due to cost cutting element but is not that bad for the price.
