Led settings doubt
Lijo
Kerala
Once you have changed the settings of the led. Does it stay the same if you switch off and switch on again?
Sent from my GT-S5830 using Tapatalk 2
Settings should stay permanent be it plasma, LCD or LED.......maybe there might be an option on the tv to save the settings.
Settings are burned in rewrittable memory chip..it will stay until u apply factory settings/change settings yourself.
