LED SMART TV or normal
nithin
TRIVANDRUM
Should i buy an 32" Full HD smart tv (Samsung 32eh5330)
OR
Buy a normal Full HD (Samsung 32eh5000)with a android TV media player with built in WIFI ?
Is there a big difference between the two?(Limited budget)
use your budget to get max screen size..not the feutures....
there are under 5k media players...buy them later..
get a 40 incher..32 is too small
if your budget is under 40k..you will get semi hd plasmas like 470 or pana x series....under 40k range...
if however if you choose 32 incher..get a simple sony/samsung lcd(not even led)...under 30k....or a semi hd toshiba or pana lcd under 24k..is just fine for 32 incher...
whats your use..movies??stb??
will use mostly for movies and tatasky HD..room is small so 32" is the best option
Wish to keep budget under 35k..
Also have a good net plan with wifi..
Thought full hd is better as we can play Full HD movies through USB..
Samsung 32eh5330 cost 34k
Samsung 32eh5000 cost 29K
Little confused whether the cheaper one with a android TV media player will give more functionality..
What android TV media player is it?I suppose it will connect to TV via HDMI.
The only feature you should check on the TV is picture quality. Decide and fix a budget and stick to it. Then within the budget choose the TV with best PQ. Smart TV, 3D, etc. are ALL useless features.
Picture quality are good in both sets
Only thing im confused is whether to buy a 'smart' or normal TV with a media player.
@dirac havent decided on media player model..will buy one having full HD support..
In such a case you can go with a smart TV with inbuilt wifi. Also these days smart tvs are playing all formats from usb.
screen to seat distance is how much...you may buy a 32..but as i said..very soon you will fel the upgrade feel
anyway about player question...a separate is goodthan onboard... many are avilbale within 5k.so buying a non player tv and saving the money and getting a good player
at 9k you will get wdtv etc...
Going to buy 32eh5330.
Turns out difference is only 2k not 5k..
Will buy media player next month..
does wifi ready means i have to buy wifi adapter to connect tv to wifi?if so hw much will it cost?
Thank u all for the replies.:)
