LG 42LW5700 + Blue Ray + Tata Sky HD + 4 3d glasses = 78K INR
humpty_dumpty
India
Folks,
Do you think this would be a good deal:
LG 42LW5700 + Blue Ray + Tata Sky HD(plus) + 4 3d glasses = 78K INR
Request your inputs plz.. Or anyone has a better suggestion?
By Blu ray - do you mean a Blu Ray player or a disc? The TV is available for about 71K INR from a quick googling.
Dont know about the deal, but the TV is class apart, both in 3D and 2D and 2D to 3D conversion .....
Folks,
My cousin got this model tv plus Tata sky hd ( no plus) plus 4 pair of glasses for 72 k, almost a fortnight back ( that deal also included the financing at zero interest).
My suggestion is get a good 3d blu ray player after really asseing yr blu ray discs procurement, I mean do you rent the blu ray discs from a local lib, or you get them from abroad, as this will help you to decide buying a region free player .
:) You mentioned bluray so it can be interpreted as a disc ... a movie could cost a thousand buck no.
Looks like a good deal.. depends on which blu ray player it is. check out its features. if you wish some more from it (like network capabilities and/or a better player) you can negotiate without the player but if that suffices your purpose go ahead.. all the best
hi, umesh. can u pls tell me that from where ur cousin bought this tv for 72k in new delhi? i m also planning to buy this tv, but in croma, its rate is 85k.
