LG G3 Reviews
forktail
Hyderabad
Initial reviews look good. Maybe this is the year we no longer have to worry about room brightness when purchasing an OLED.
I'm a bit confused about it. Not sure if all the models in the C3 range will have MLA. Please wait for the same to launch in India. Somehow I get the 'Hisense feeling' last year they launched all mini leds in Americas however they changed the panels while launching in India keeping the model name same!! I hope nobody follows the suit..
Wait for reviews> wait for India sales> check the prices> wait for Diwali/ other sales> get the TV in proper discount> be happy!
I have the G2 and have no issues with image not being bright enough in my well lit living room. if the G3 is improving that even further, then it will be interesting to see what exactly changes.
MaSh
Even with a cx, with a service remote, you can remove the automatic brightness limiter to equal a C2 in brightness. But what matters is, in c2 there is a heat-sink. So it works without having to fear burn ins.
No you can’t make it equal to C2 in brightness. You can make some C1s equal an G1 in brightness but only those with the evo panel.
Also, C2 doesn’t have a heat sink. They all have an evo panel. G2 has a heat sink.
i have absolutely no complaints with my LG G2s performance in bright room. 9/10 times it can easily fool anyone into beleiving its an LCD brightness
Brightness when i got LG to remove the automatic brightness limiter made it look like a weird exotic QLED channel with "vivid" picture, it was looking better than most TVs. But i put it back to original settings.
You still can't make it as bright as C2, no matter what. C2 will still be brighter.
Also ABL is only limited for static objects.
HEAT SINK as in? when i go near the front panel after long usage i can feel the hot/heated air.
I don't think they will be providing 5Yr Panel Warranty for India. I be really surprised if they do.
98% chance they wont.
