Lg la6130
Dude not a great TV.. better check SONY or SAMMY in this range. Otherwise consider LG 6910 priced a bit higher.
think so,better check SONY or SAMMY in this range. Otherwise consider LG 6910 priced a bit higher.
ODzYjZ
all other tvs price u r referring are on the higher side.
lg la6130 is the cheapest just like an led tv having 3D option in addition.
did u check this model? what's the reason u r saying no to this model?
my budget is only 60k.
I have bought 55" LA 6200. It was good for 125K. PQ is good. has good options. But we will mostly use only some part of it only regularly.
I was satisfied with that TV
SAM_NEO4U/ Polaris - getting a 3D without smart is not possible (or should i say very less possibility - keeping in mind the after service you need for it!). You would better buy a 3D with smart and don't use the SMART features. Buy a brand which has a good A.S.S rather than a brand (including model) which is not popular. That would put you in peace-of-mind. And to add - there are no (much) reviews on the model you specified. So go, on your choice. Like other's mentioned Panasonic, Sony, Samsung, LG (on various models) - some of them which are well regarded in the TV industry.
Speaking out of Experience, The PQ is decent, 3D is good, but this is my 2nd TV after the first LG 55LW5700 was replaced for bad LED bleeding/Flashlighting. Fortunately for me they did not have the 55LW5700( 2011 model) so I was given the LM6700(2012 model) but there is random bleeding there on this TV too. So try for Sony / Samsung, I do understand they are a bit more expensive, but I BELIEVE the bleeding is less/non existent
