Lg ls4600
frosts
How is this TV overall in terms of PQ. Wanted to use it in my bedroom which has viewing distance is 8 feet
Getting this in 32-33k .(32 inch)
Would also like this model owners to tell their till date experience
if its a long term invest ment why dont try semi hd 42 plasma at 36k or toshiba 40 inch lcd at around 39k
or toshiba 32 inch is only 17k...also can try that..just an idea
Yes its a long term invest as i dont tend to replace it atleast 7 yrs..
I dont want plasma for my bedroom as the tv will be very near to my huge long windows ..
I wanted a 32 inch as I am planning to buy a 40 inch for my living room so dont want same inch on both places..
Toshiba lcds are good ??
Panasonics LED not worth as the panels are made by LG so the price for TV will be more than LG..
Any suggestions in other brands.. My budget is in 30-35k
for 32inch toshiba semi hd is for 17k only..quite cheap..otherwise semi hd sony within 27k is best option....an idea
or u can do....a 50 inch plasma/lcd/led (say 70k) for beutiful hd movie experience and a 21 inch crt (8k) for bedrooom serial/general etc purpose....that will fit ur budget of 32 inch(35k) and 40 inch(45k).....that will be a killer package...
