LG Plasma lg 42pj560
vinniks29
india
Hi All,
I am planning to buy the LG 42pj560 mainly for gaming purpose (PS3). Can anyone please tell me what is the response time of this plasma television. I was not able to find this information on their website.
guess thats 0.0010 ms 720p (HDTV) 1366 x 768 pixels NTSC, PAL, SECAM, DVB .. however its 720p and if you have speakers.. then you can go for the pj350 itself.. as only diffrence betwwen 350/560./650 is 350/650. with and without border
560 only sound.. rest all same... so go for 350 if its just screen.. also its 720p..
what console you want to add and whats the budget buddy..
thanks for the details...i don't have speakers that's why i decided on 560.
console i am going for Playstation3 and my budget is of 50K for television.
If you are going for a set primarily for gaming, LG might not be the best choice amongst plasmas for two reasons - the IR is reported to be worse than other plasmas and the input lag is unusually high by plasma standards.. do read some reviews on 2010 LG plasmas at avforums.co.uk or hdtvtest.co.uk before you make a decision.. here's the link to one such review..
LG 50PK590/ 60PK590 Review: 1080p Full HD Plasma TV
Primarily for gaming what other models are doing good in the market nowdays in india? 42inch and in the price range of 50K.
depends on model.. the details say that it is .0010ms.. however depends how much can it actually squueze out of that..
still 50k is a decent budget for 42... you can also look for pana or sammy. if you looking for better picture quality...
