drdsak
Hi everyone, this is my first post
I want set up a HT in my living room
Dimensions are 17' x 18'
I am planning to buy
- TV - Panasonic 42 inch ET5 series (TH-L42ET5D) ~ 70k (Passive 3D)
- Onkyo HT - S5400 7.1 Home theater system ~ 50k
- Sony PS3 play bundle ~ 18k
- Logitech harmony 700 Universal remote ~ 6k OR Harmony 525 ~ 3k
- Videocon d2h HD STB - I already have Videocon d2h HD for my bed room so I just have to get multiroom connection an I am very happy with d2h
I want passive 3d as I found it good in LG, also panasonic has built in wifi, smart features, not available in other tvs for same price
Onkyo fits the bill for 7.1 as other mix and match setup are very costly (I want to setup everything once and I want 7.1 as I already have old Sony 5.1 DVD HT setup)
Logitech 700 has 6 devices support and good database and learnin too, can control ps3 vis HDMI CEC (confirmed), but 525 though older supports 10 devices.
Other components required are HDMI cable
Also onkyo supplied speaker cable is too short for surround back speakers
My queries are:
1. Is DAC speaker cable AWG OFC good(sold at hifimart)?
2. Which gauge to get - 14 / 16 / 18 / 20? Should I
3. Will it void warranty if I use other cables with Onkyo HT?
4. Is DAC HDMI 1.4a cable @ 1.1k is good(again sold at hifimart)?
5. Should I replace all cables from onkyo with DAC ones for good performance? Or just surround back?
6. Should I get cable for subwoofer too? I ask this because I have doubt that if I use different cables for each speaker the performance will be affected.
7. Any other good and cheap hdmi speaker cable suggestions?
8. Any other HTIB or AVR + speakers less than 50k? I know there exists none, still any suggestion
9. Onkyo does not show 24p support, dont know whether its going to be a problem
10. Any other TV suggestion?
11. Will Onkyo play apple lossless from ipod?
12. Will PS3 play back apple lossless or flac?
13. Is Logitech Harmony 525 supporting 10 devices is better option than Harmony 700? Any user feedback
14. Is 42 inch TV small for my room length (16 foot)? Should I go for 47 inch?
My queries are:
