Looking for a 55" UHD HDR TV
rageshjaiswal
Delhi
Hi I am looking for 55 inch UHD HDR TV within the budget of 80k to 100k.
Priority
1. Mostly OTT content.
2. No gaming
3. I do not own sound system.
4. Should have good brightness.
5. Will using it for next 9 to 10 years.
6. Viewing angle is not at issue, can go for VA panel.
Thanks in advance.
The 2021 model Samsung Frame is a good option.
Priority
2. No gaming
Thanks in advance.
Priority
2. No gaming
Thanks in advance.
You can go for x9000h if it's available.
Thanks for replying,
Earlier I was eyeing on Sony 9000h but I could not found it in stock, got one demo piece at reliance digital not sure is it right to go with Demo piece.
I have talked to one of the Samsung smart plaza they are telling they have both 2020 and 2021 model of The Frame.
I am not sure which one to go with.
Please suggest.
I did some searching and found a demo piece available in reliance digital store for 88K (55 inch).
Haven't bought any tv since 10 years, quite not sure about how these demo piece work as they have been kept on continuously.
Is there any parameters to check for demo model.
Please suggest as this would very helpful.
It's better to go for a fresh piece. You can get a fresh one around 95k if you bargain.
