Hi all,
I'm looking for suggestions for a subwoofer, budget range of 30-40k.
Was exploring brands like Yamaha, BIC, Elac, etc. However, the dealer is pushing Taga Harmony platinum SW10 which falls in the budget and def tech prosub 1000 (which is a little more expensive at around 50k). I'm a bit wary of the brands the dealer is recommending as I've seen some negative reviews on Taga and Deftech on forums.
Please suggest which ones are worth considering. I'm not a fan of boomy bass which lingers around. Looking for depth and tightness.
Also, is it worth moving up my budget to an SVS SB1000, I'm not an audiophile by any means and this is my first HT setup.
My usage would be 70% Movies, 30% music. Room size is 12x25 with the HT setup on the width (smaller) side, and distance from the speaker around 12-14 feet.
Planned setup:
I've ordered Polk signature series 5.0 speakers
R/L S55
Center S30
Surrounds S10
AVR: Looking to get my hands on a Yamaha rx-v6a 7.2 channel AVR.
Thanks in advance!
Planned setup:
R/L S55
Center S30
Surrounds S10
Thanks in advance!
