Looking to buy a full HD LED tv
Xamanus
hi guys, Could you guys help me in suggesting which tv to buy ?
Im Looking to buy a full HD LED tv for my room, 32 inches,
Will be my first tv after years in my room,
My require would be as follows -
Ps3 gaming / laptop gaming ( laptop is full hd 1900x1200 , graphic card nvdia 9800GTS, so want my tv to be something on a similar level )
Watch sports, movies and other tv shows on full hd if possible on set of box.
Modern features like - usb, wifi in tv, skype etc.
Led tv must be 1900x1080 minimum.
i think thats about it, My max budget is 50k inr.
I have shortlisted two tvs by Lg
LG Full HD LED LCD & TVs - Model 32LE5500 LED LCD
and
LG 32LE4600 LED LCD TV - Jazz now in LED! - LG Electronics IN
Which one is the better tv? the only diffrence is that the second tv is Dynamic Contrast Ratio 2,000,000:1 and the first 5,000,000:1. also the second tv has sound features +
so does dynamic contrast ratio make a big diffrence ?
im getting the first tv lg 5500 for 45 k as market rate is 50k, my friend dads store.
Also please suggest me more tvs better or as good.
thanks guys:)
Like sanjay said bigger would be better, but I doubt Xamanus would be able to get a bigger screen size LED TV for his budget, I mean the 42 inchers are closer to 60-70k.
gaming on a 32 incher :indifferent14: with all your needs why not you look into a plasma.... Panny 42V20D is a perfect fit to your requirements if you can bump up the budget by 10k...
thanx for your replies guys
Firstly LED VS PLASMA >>> whats better? i heard led is far better.
secondly wont 42 inches be to big for the room ? i have a 42 inch plasma in the hall. if its alot better then i will re consider, but i doubt it my dad will agree to stretch so much. but will the Picture QUALITY be better then the led tv??
the tv is for 45k + i have will buy a home thetare system + hd set of box so im going be 55k+
please guide me on these points
thanks
so whats better LED or PLASMA? I heard led is far better in terms of picture quality.
if the plasma is alot better then i may consider it, but i doubt my dad would agree, anyway can you explain why i should get plasma as im a newbie to tvs.
Just check out the Pana v20d in a store and read up about it in on the thread on this forum. you will have enough reason to buy it, :)
I got my 32LE5500 installed last week, except for the audio part, every feature looks great, needless to say the HD picture quality. I am not a fan of gaming and hence did not tried the same -Excellent product
Here's my tuppence...... LG4600 vs LG5500 except for the Dynamic Contrast Ratio [2lacs:1 vs 5lacs:1] and the Netcast - Broadband features on 5500.... Go for LG4600. Response time of both is 2.4 ms [decent for gaming]. Otherwise the rest is negligible difference. DO NOT FALL FOR NETCAST/BROADBAND features...these models cost 10-20% more for just a few 7-10 widgets thrown in. IF u have a net-conn of 7 MBs or more...then fine. Else forget it.
I am about to close a deal on LG47LE4600 for 71K... I may knock off the offer of the Blu-ray Player and thus reduce the deal by Rs3500/-
do you know the price of LG42LE4600
