Looking to buy avr and 5.1
arunsa
New Delhi
Hey everybody
Im looking to buy an avr and 5.1 speaker,
I have a tight budget of 50k can go upto 60k if really needed.
I have read good reviews of denon x500 and ba xs 5.1 on this forum.
Im a BASSHEAD so I plan to add a klipsch sub sw112 or anyother big subwoofer later to the system.
I will be using it for listening music mostly and rarely for movies.
Please Help.
You might want to state your room size, % of usage - movies vs music depending on which suggestions you may get The combination that you have mentioned is good, however consider compact bookshelf speakers too.
Hi arunsa,
It would be advisable for you to carry your favourite music and movies (if possible) and go audition as many systems as you want...end of the day it depends what would appeal to you in performance and yes budget......
You can shortlist a range of auditioned systems where we can then possibly further provide some guidance...there are threads related to Home Theatres which you might have read...you can click on our user names and check responses provided in the past....
if u r basshead what I can suggest that try to get Vintage 2 channel amp and 12 Inch speakers If you can get . You may get it for (Both) around 15 to 25 K ..and it will not disappoint you!
70% music! - Then I suggest used stereo amplifier and used good FS. May get for 50k budget.
Agree with hemantwaghe.
