I've no doubts on the quality of Panasonic products. However, the concern is the after sales support of their products. Please check the same if you can before you go ahead and make the purchase.
Go for L32E5d instead,good value for money Led. i too planned to buy x50d earlier because my budget is limitted to 35k.but later i came to know x50d doesn't support all video formats and also not a Full hdtv.so i bought e5d.
Market price of E5D(32 inch) is 41k but you can use your bargaining talent and strecth upto 37k.( i purchased e5 for 38k in my city but only via EMI.:sad
if already decided to buy 32 inch only..pls buy semi hd.the diffrences in a 32 semi hd and ful hd panel are really really unnoticable..experiment it..plus just think how many times u will send true full hd signal that is from a br player..so if buying 32 incher.dont waste ur money on fhd..buy semi hd and use the money to upgrade ur sound etc...
