I have a Hypex Ncore (NC252MP module ),150Wx2 @ 8 Ohms, Class D amplifier .
I run it off a Laptop> Topping D50S DAC >Schiit Freya+ Preamplifier > Hypex Ncore Amplifier > GR Research X- Statik speakers .
I find that the volume level to be lower than expected . I am able to max the volume out in my small apartment which is quite surprising . ( i could not do that with my previous and much older Yamaha and Pioneer amps)
The output voltage of the DAC is 2 Vrms which is standard for a DAC ( RCA) . I am able to get some more voltage gain when running on the Tube stage of the preamplifier , but that is not sufficient.
Any ideas on what could be the problem. Could it be a problem with the Class D amplifier or does the amp require signals with more gain from the DAC ? Or could it be some other issue ?
