Ashish6464
Is it possible to make a home network using wifi routers, so that i can access my Music, movies, pictures etc stored on home PC on my home theatre, TV, mobile or any other device? If yes how to do it in cost effective way?
I think the most stable and reliable solution to your scenario is to use a powerline extender, unless you can pull lan cable. Fully Wifi solution is likely to be unreliable over two floors.
Hi haisaikat,
Yes the denon avr x1000 is in the first floor in home theatre room.
I am confused between a access point router and wifi extender bridge.
can you tell what suits best for my situation?
Also there is very little range on ground floor as the router is on first floor, so should i buy 2 wifi extenders one for HT room and other for ground floor?
