Adding thread for enclosure solutions:
Do add any info if you get quality enclosure (not poor fm radio/cheap looking local amp cases)in your city...
I have developed a wood metal enclosure in my delta sigma dac thread.Wood + metal look very good but a little effort is needed.
I have contacted 1 -2 companies for a small qty.. i recieved
quote of 380Rs . They are exporters [i will not disclose name to prevent flooding with emails,will disclose all if someday group buy becomes possible]
specs here :
Sheet Metal Box
Dwg No. xxxxxxx
Material:CRC Steel Sheet
Thickness :1.2 mm
Finishowder Coated
Cost Per Piece:Rs380
Size: 25x 25x 5 cm(can be adjusted)
qty is 20 pcs
That is the problem... i need 3 of them.
If some takers can get them done .
Also other quotes welcome.. I have not checked local workshops yet! These boxes may be used for valve buffers
,preamps etc. Stepped attenuator boxes.Toroidal power supply too.
specs here :
Sheet Metal Box
Dwg No. xxxxxxx
Thickness :1.2 mm
Finishowder Coated
qty is 20 pcs
