Hello FMs,
I have a room size of 16x11feet and I have almost decided on Marantz 6013 and Klipsch speakers after spending much time on comparison and discussing with others. I like everything about SR6013 other than one the display part. I feel it is pretty small and has less information compared to 7103. I don't feel it is a good option to spend extra for 7013 for having a display. I would watch movies and listen to music equally.
I am still confused about the speaker package. I have now decided for Klipsch package and svs pb 100 subwoofer
Klipsch R820 F TOWER
R34C
R14S
Svs pb1000
These belong to the reference series and the tower has 8" inch woofers. I hear that reference series' high is somewhat piercing to the ears but at the same time reference premium has better highs and has been refined. I get the reference premium RP600F for almost or for a bit higher price compared to the R820F but then the driver would be of 6".
I would be thankful to everyone if you can help me with the your suggestions.
Thanks,
RMRanjith
R34C
R14S
Svs pb1000
- What would be the best configuration for the towers ? 6" RP600F or 8" R820Fs.
- Is R34C a good center or to be replaced with R52C?
- Is there any equivalent from Denon which can match with Marantz 6013 both in terms of price and performance?
- I get these at these rates. Is this decent rate or that I am quoted an exorbitant price?
- Klipsch R820 F TOWER - 88000
R34C - 33750
R14S - 24000
Svs pb1000 - 57700
Marantz 6013- 82570 - Polk RTiA7 series is cheaper compared to this Klipsch. Going with Polk would be a better option?
- I believe SVS PB1000 can beat the Klipsch subs anytime but again the price is high for the SVS.
- Should I spend extra for the 7013 for the display feature. Other than that I believe power output wise the 6013 can drive Klipsch without any issues.
Thanks,
RMRanjith
