Gaurav55
I am confused to buy between three av receiver marantz NR1609 or Marantz SR5013 or Denon AVR-2600H for movie and music
Does Denon 2600 is for movie not for musicIts better if you go with Marantz NR1608/09 with pre owned PA/IA for front speakers within the budget. You may get better results than 5013 and 2600. I am using NR1608 with Denon avr as PA for front speakers and combo sounds lot better than standard 7 channels avrs in HT or stereo mode. Both the avr shares equal load and both runs cool for longer listening sessions. If you are intended to you avr in 5.2.2 mode, you will get more than enough power across all channels (for better dynamics) than a standard 7 channels avr. Save extra money with NR series avr and invest that in pre owned PA/IA.
Which floor standing speaker is best for itThere is good number of FM happy with Denon x2000 series avrs in both HT and Stereo mode. It depends on the end user. Most of the time speakers, placement and calibration make the difference . Avrs are just a part of it . Audition is the best option to judge the component.
+1 to this. reasonable advice!Its better if you go with Marantz NR1608/09 with pre owned PA/IA for front speakers within the budget. You may get better results than 5013 and 2600. I am using NR1608 with Denon avr as PA for front speakers and combo sounds lot better than standard 7 channels avrs in HT or stereo mode. Both the avr shares equal load and both runs cool for longer listening sessions. If you are intended to you avr in 5.2.2 mode, you will get more than enough power across all channels (for better dynamics) than a standard 7 channels avr. Save extra money with NR series avr and invest that in pre owned PA/IA.
ur ears,choice and taste & money spending capacity and last self satisfaction .plz believe in audtion .Listen to different speakers with ur source song and receiver if possible ,then select among speakers.Which floor standing speaker is best for it
Q Acoustics 3050 or Dali zensor 7 or Elac F6.2 or Wharfedale 230 or any other please suggest
There is no option of audition in Uttarakhandur ears,choice and taste & money spending capacity and last self satisfaction .plz believe in audtion .Listen to different speakers with ur source song and receiver if possible ,then select among speakers.
What is it's means+1 to this. reasonable advice!
+1 means I agree with the comment. In this case the advice given by @rpmahale.What is it's means
