Marantz PM7003 series discontined
iyersn
It appears that the Marantz PM 7003 series has been discontinued, PM 7004 has been introduced.
Has PM 8003 also been discontinued? Found it tough to get one.:cool:
both models are discontinued
the 8003 has been replaced by the KI but the KI is infereiror
the 8003 was a true gem
Original made in Japan
full copper chasis and copper gold plated binding posts
the KI is nowhere close
But both the amps continue to be listed in their singapore website.
N.Murali
Sir,
Did see a Marantz brochure at Alpha yesterday- did not contain either of 7003 or 8003 but had 7004. I am not sure if the Europe site has these two models.
Only Boomerang CST seemed to have the PM 7003 -neither of Alliance 4 or Viola or Alpha had it.:sad:
hi can anybody help me to repair my PM 7003 Amp
when power on all led lighting, relay clicking
no other response...power is ok, but cm not responding
You could have a bad preamp section, isolate the problem. Send in output into the main in form a pre amp and see if you got sound. If you do, your power amp section is ON, problem is in Pre amp. If no sound, power amp is bad. Repeat by sending from pre out to another amp. Oh, is it internally jumpered ? If not, do you have the jumpers in place, or an RCA cable pair between main in and pre out.
Isolate your problem and locate it and go from there.
Cool.
Srinath.
