Marantz pm7200 : Looking for opinions
corElement
gurgaon / Delhi / NCR
Seems like an interesting mid 2000s model which let's touch switch between class a and class a.
75 MODEL PM7200 TECHNICAL SPECIFICATIONS
Power output (class AB operation)
RMS 8 ohms (20 Hz-20 kHz) ....... 95 W
DIN 8 ohms .... 105 W
THD at 8 ohms RMS rated output ...... 0.03%
Damping factor .. 150
Power output (class A operation)
RMS 8 ohms (20 Hz-20 kHz) ....... 25 W
DIN 8 ohms .... 28 W
THD at 8 ohms RMS rated output ...... 0.03 %
IHF dynamic power (class AB operation) 8 ohms .........
Signal to noise ratio .......... 85 dB
Frequency response (–1 dB limits, Source Direct)... 10 Hz - 50 kHz
Weight Unit alone ............ 12.3 kg
Someone online said there signs of cost cutting in stock form, such as poorly performing and noisey opamps in the preamplifier stage, and bad output connectors, these are easy to change and make a massive upgrade to the sound quality.
This person is not responding to me. I wonder if anyone else here is familiar with what he's talking about and if it's easy to change.
