Marantz SR5005 Or Denon 1911 ??
thejas23
Mangalore
Hello ,
As i was looking for 5.1 Rec Thats Denon 1612 , Most of u Guys rec to have a check on 1912 But i am looking for something inside 30-32 ,I have no way plans for upgrading to 7.1 so even if the rec is 7.1 i will stick with 5.1
Denon Group buy where i came across 1911 for 30k but due to No Stock he offered me Marantz SR5005 for 32k
5.1 Speaker which i have finalized - pioneer sp-pk21bs
Which 1 to go for i am really confused
1,Denon 1612
2,Denon 1911
3,Marantz SR5005
most online reviews and a lot of people on this forum recommend Denon AVR1911.
I have not listened to both so can't tell the experience. You can also consider Yamaha RX-V667- available for similar price. Good reviews.
I will recommend Denon over Marantz for movie watching.You get movie effect better with Denon.Marantz 5005 is neutral & sounds good for music.HT its OK,but Denon will be good.
