Max room size for optimal performance of speakers.
rpradeep
Chennai
Dear friends,
What is the maximum room size for satellite speaker packages, bookshelf packages,FS for a 5.1 setup for the speakers to perform better? THanks in advance for your replies..
Thanks,
R.Pradeep
Unless you are building a house, let me rephrase your question - which speaker package would fit what room size?
The answer is not that simple. It is not just the speaker package but a combination of speaker set, amplifier, room acoustics, seating and ambient noise that determine what you install.
But to answer your question let me give some rough idea:
1. Satellite speaker set - upto roughly 150 sq. feet
2. Bookshelf set - 200 to 300 sq. feet
3. Floor standing - 300 sq. feet and above.
As I said before, there a number of other factors. Another important factor is your listening sound. Are you content with tinny sound, or would you look for clarity, sound stage, etc?
Thanks for your reply venkat...
The combination wud be like this:::
Denon 1911
Energy Micro (OR) QA cinema (OR) Canton movie 125
The location is a hall and it measures upto 200 sq feet and need to be wall mounted instead of stand mounting....
R.Pradeep
All three choices are good, and you should choose the one your ears like. Between the three, the QA would give slightly deeper and present a larger soundstage as the 2010 are comparatively larger speakers.
