koushik
Nothing Like Anything \m/
I recently moved to Hyderabad leaving all my HT & Stereo setup back in Kolkata. Started journey with different idea in mind but as days are progressing it is more and more apparent that I am here for longer term than I anticipated.
Hence the need of a TV to start with for the family & myself.
After all relocation & settlement expenses, I was left with lesser budget for the TV. And with good reviews all around, decided on Micromax 32" for Rs. 13,790.
Amazon is amazing. You actually need to see the packaging to believe it. Unbelievably secured with more than 50 air packets all around the original TV carton.
Inside the box:
The 32" LED TV Unit
Remote Control (2 x AAA cell)
3.5mm to 3 RCA AV cable
AC cable
User Manual
Basic packing from the manufacturer is also very good, tight and secure.
Technical Specification:
Screen Size - 32"
LED Type - 81cm TFT LED
Display Resolution - 1366 x 768
Viewing Angle - 178 H/V
Lamp Life Time - 30, 000 Hours minimum
Power Consuption (Max) - 45 Watt
Audio Output (RMS) - 8W x 2
Connections:
USB
3.5mm AV In
3.5mm AV Out
HDMI
Component In
2RCA Audio In
VGA socket In
Antenna In
2-pin AC socket
Video Performance:
I have a TataSky HD connection. The SD channels are decent and when watched from more than 10ft away is looking quite good.
The HD channels are extremely satisfactory when you consider the price. Infact my Sony LCD which is almost 20k costlier than this one is more or less producing same quality picture in terms of clarity.
The pic quality by default is a bit warm and over saturated esp. in the region of yellow, lime, light green tones. This, however, makes Discovery/AP/NG channels absolute delight to watch.
I found the default picture settings to be the best and may be tone downing the saturation level a bit makes it more soothing to watch.
"P. Effect" aka Picture Effect button on remote gives you Personal, Bright, Standard and Soft settings.
Sound:
The quality of sound is, according to me, very good albeit a bit low. At 50-60% is the normal volume to listen at but the quality of sound is really very good. Spending some time and setting the equilisers intelligently bought out the best in it.
"S. Effect" aka Sound Effect button on remote gives you Personal, Stereo, Music, Movie, News settings.
USB playability:
It played every format that I thrown at them - avi, mp4, mkv
The AV quality from direct USB is good but not great. I got better quality while playing same files through Asus O!Play connecting via HDMI.
On screen graphics & menu navigation:
This the weakest part and really a bit frustrating. The response is not how you like it to be. Slow responding and very basic. Doesn't look nice on screen. The icons and navigation is very trivial and looking cheap . This is certainly not deal breaker for me considering the PQ for money. I think we will get use to it in some time.
Verdict:
A bit louder sound and better menu navigation and graphic is desirable amd much needed too.
Picture Quality: 3.8/5
Sound Quality: 3.2/5
Features: 2.0/5
Value for money: 5/5
Overall: ****1/2
Inside the box:
The 32" LED TV Unit
AC cable
User Manual
Screen Size - 32"
Connections:
USB
3.5mm AV In
3.5mm AV Out
HDMI
Component In
2RCA Audio In
VGA socket In
Antenna In
2-pin AC socket
Video Performance:
Sound:
USB playability:
Verdict:
Features: 2.0/5
Overall: ****1/2
