chetanmohanty
Hello members, i am in need of a wall mount bracket with tilt for my Mission LX2 speakers. these speakers will be used as surround. Please help me with pointers to online websites / shops in Bangalore.
There are models available in Amazon.
Actually my couch is against the wall , so i am planning to put the speakers on the wall pointing towards listener. So i am looking for a bracket that allows tilt as well.I am using this particular wall mount stand from Amazon. This is good and can hold BS speakers up to 5kg (by spec-wise) but you can load more based on the wall screw you use to install them. I believe it would suit your needs considering your speaker dimension.
MYL Speaker Wall Mount
My Klipsch R15M surrounds are sitting in this stand only. Their flexible holders are adjustable and its swivel design allows you to tilt it horizontally.
Does it allow tilting vertically ?
Apparently this one is a good one costing approx Rs. 4000/- equivalent abroad & sold at a ridiculous price here.
Pls see if you can get it from abroad or Sriram's option also seems good.
Can you tell me why you wanted vertical tilt? If you are going to keep the surrounds, it has to be at the ear level otherwise, your high frequencies may not be heard as expected.
