I am planning to add 6 Speakers to my HT setup. Fronts MA Silver RX6 and Heco Center Will remain unchanged, these speakers will be used for upgrading my 5.1 to 7.2.2 (supported by my Marantz 7010) currently. The current Surrounds, I am Planning to discard them as they are from My 7 Yr old Yamaha HTIB. I am sourcing the Speakers from UK as of now, but I can Buy it here if I find comparative Pricing. I am not bothered about the packaged Subwoofer because I will not be using them in any case. all of these are 5.1 speaker packages and I am planning to buy two spare speakers to complete my 6 Speaker requirements. Else I could by one more Center speaker and make it 6 speakers with two Center Channels (to be mounted vertically as surrounds hopefully that works out)
1. Monitor Audio MASS : Small, Classy, powerful and designed to be Mounted easily anywhere with minimal issues, don't know about how to Mount Them in atmos Config. wall mount should be procured seperately. Should blend with My MA RX6 fronts easily.
https://www.monitoraudio.com/en/product-ranges/mass/mass-5.1/
2. Focal Little Pricey but more resolving according to reviews, Mounting brackets are atmos friendly
https://www.audiovisualonline.co.uk...-evo-5-1-2-black-dolby-atmos-speaker-package/
3. Dali Fazon Micro : Cheapest of the Lot but not greatly reviewed
http://www.audioaffair.co.uk/dali-fazon-5-0-speaker-package
4. Q Acoustics 7000i very capable and reviewed better than MA MASS , bit pricier but comes with Mounting Brackets, getting a Spare speaker is tough though.
Other Options I am considering is 6 Polk OWM3s/ S15s, Or Mordant Short M10s Or other Cheaper Speakers . I didnot like OWM3s during audition much.
Bit Confused as I don't want to Cross the budget of 60 -70k for 6 speakers including mounting options.
Any other options that are possible in this budget for 6 speakers with easily Mounting options?
Anybody using above mentioned speaker packages and your experience on Strengths/ Weakness ?
I am not averse to DIY options as well , Kindly Shoot Your suggestions ...
