Multiroom Audio with timer ?
Kannan_madhu
Thrissur, Keralam
One of my friend has a particular requirement , He want to play a particular song file
(not available on streaming services ) particular time in all rooms of his home . It has to play wireless as new wiring is not possible . . Rooms has smart plugs which can be controlled from Alexa or google assistant What would be the possible options ?
try arylic only product which plays in multiple room without any delay which is most important while playing wirelessly
it also supports airplay and other apps
its kind of development board type need some tweaks and work to make it work..
Unfortunately google chromecast audio was discontinued.
Thanks for the suggestion i have a Arylic amp but a timer option is required
