Music System in Car
rohansave
Hello,
I have brought a new car Verna...i need to put a good 2 din system with speakers. Can anyone of you suggest a good accessories showroom in Mumbai Western side where i can visit and select the product. Also let me know for which product should i opt for? whether Sony/Pioneer and speakers also????
Thanks....
Rohan
whether Sony/Pioneer and speakers also????...
Hi Rohan,
It depends on your budget.
I personaly liked Pioneer ... SONY is average..
Kenwood , Alpine are also good. Pioneer is cheap and best.
If you are looking for hifi system, then you may need to add car AMP / Component speakers and Woofer if you need more bass on top of head unit.
You may select the two din model here : http://www.pioneer-india.in/ and purchase in any car audio shop.
I'd say use the stock system for atleast till 1st or 2nd service listen to the music you will know better where the system is lacking ... Then later go for a good HU , Amp , Components and a Sub in rear....
Alpine Eclipse are best headunits but costly.. Kenwood and Pio are vfm ..
Pioneer is loud and kenwood is more balanced...
components there are tons of brands available depends on your choice of music you can choose the brand...(focal, Bull, Hertz, Rainbow, JBL , Infinity )
Amp Alpine , kicker , JL , Crunch make some good amps.
Sub - JBL , Rockford....
HTH :cool:
Hi, you can try shop name PLANET, it's on Malad - Goregaon S V road just before the Goregaon west - east flyover starts
Check for Infinity speakers / components not sure if they stock but I infinity's are one of best atleast for me.
Cheers...
